Laundry rooms as described require minimum 1 x 15A circuit and minimum
2 duplex receptacles.
Code refs include 26-710(e)(ii) and 26-722(b).
Canada sounds like they need to beef up their minimum requirements. Unfortunately lots of contractors will not go 1 step over the absolute least they are forced to do.
Depending on their power (amperes) requirements, a gas dryer and a washing machine may be plugged into the same 15 amp branch circuit.
You might not be able to use a clothes iron or hair dryer at the same time the washing machine or dryer was running.
Additional receptacles may be installed in the laundry area, fed by other branch circuits not dedicated or exclusive for specific rooms or purposes.
Did you (the op) read my response in post #2?
Seems you're too busy being disgruntled to communicate effectively.
That could well be the root of the problem between yourself and the
contractor too.
I thought comment #14 covered it all. I did find the minimum codes you stated. Thank you for the specific numbers. Could not find them. But when a moron like me reads all over that I should be connecting both machines to a 20 amp circuit, I'm thinking the worst. I won't rant here anymore. Want more on my situation, PM me. I'd be glad to chat.
Your shooting the messenger (your electrician). You have a GC, he is the one calling the shots with the electrician (and any other tradesmen there). The electrician did a code compliant install, if you requested 'over and above code' ie, extra circuits or receptacles, you need to take it up with the GC.
The electrician 'bid' on a job spec'd by the GC. If he does extra, it's on his own dime unless the GC approves the change.
