new problem
It was -30 yesterday and the furnace was acting up again, went back home and there was no heat, checked outside intake / vent, no obstruction, air filter is clean, the furnace spat out a whole bunch of error codes, 272, 227 and 250. called the installer immediately, however, 5 minutes after I hang up, the furnace reset itself and started working and has been working fine ever since. is it normal for Lennox furnaces? shall I be concerned? BTW, when the burner kicks in, it always gives error code 229 and goes into HIGH, then down to LOW after less than a minute, checked Lennox manual, it says "no action required". also, even though the installer came in and sloped the furnace, water still gets into the inducer motor housing, not as bad as it was though (based on the noise level), and the inducer motor seems to run really hot. :confused1:
