How can this be explained in the context of Mr. Ohm?gregzoll said:Yes it can.
What are your contact locations? Line to line? Line to neutral? Line to ground? What is the value of the reduced voltage?ndmick said:measuring at the subpanel where it goes into the main breaker.
Nothing to do with Ohm's law. Breakers go bad, whether they are a Single pole or double pole. Just because you have two poles on a breaker, one pole can go bad, while the other still works fine.How can this be explained in the context of Mr. Ohm?
Obviously a failed breaker could allow ZERO volts to be realized. I mistakenly interpreted your comment to mean that a faulty breaker could allow a partial voltage to be realized. Say, 50 volts for example.gregzoll said:Nothing to do with Ohm's law. Breakers go bad, whether they are a Single pole or double pole. Just because you have two poles on a breaker, one pole can go bad, while the other still works fine.
Even more fun, when you have a 400amp breaker blow, causing the other phase to blow out that side. Nice fourth of July action.
I just replace big 1600 amp breaker for my industrail customer it was no fun with that one it did knock the POCO transfomer out of commison end up replace that as well. ( BTW it is 415Y240 volt system )Nothing to do with Ohm's law. Breakers go bad, whether they are a Single pole or double pole. Just because you have two poles on a breaker, one pole can go bad, while the other still works fine.
If you did get 50 volts going thru the breaker like example then you have something is burning inside the breaker useally the concat is bad or pitted up pretty serious. For sure you can hear the cracking sound ( I can pick up the viberations so I know it is cooking pretty hard )Obviously a failed breaker could allow ZERO volts to be realized. I mistakenly interpreted your comment to mean that a faulty breaker could allow a partial voltage to be realized. Say, 50 volts for example.
