This problem just came up - outlet been working fine for 20 years. I have an open neutral on just the one outlet in my laundry room. I pulled the outlet out - just one black wire, one white wire and a ground. Changed out the outlet - no difference. My furnace also runs on this circuit and it's working fine - can't find anything else.
I checked voltage at the wires coming to the outlet - black to ground, I have 124 volts - white to ground, I have 17 volts.
Any suggestions?
Thank you,
ryan
Any suggestions?
Thank you,
ryan
