In my detached shop, I had 12/2 coming off a breaker in the main panel and going directly to all the lights. All the lights are fluorescent, and controlled with pull chains.
Since I don't like to wave around in the dark looking for a pull chain, I added new 12/3 going to a light switch near the panel (which is conveniently near the door). Black runs from the breaker to the switch, then red from the switch goes back into the panel. The red is nutted to the old Romex coming into the panel and going to the lights, so all lights are now controlled with one switch.
It occurs to me that I now have two neutrals (and grounds) on the same breaker -- one from the 12/3 going to the switch, and another from the old Romex feeding the lights. Both feed into the neutral bus bar at different locations.
Is this bad?
I pulled a permit and will be getting it inspected, but I don't want the inspector to think I'm an idiot... just to be clear, I am an idiot, but try to hide it.
P.S. If you're wondering why I ran 12/3 to the switch instead of using a switch loop, it's because there's a second switch there that runs to an exterior light. That exterior light is fed from the switchbox, so it needs a neutral there.
Is this bad?
