1 - 6 of 6 Posts
· Cruising into the sunset
I thought I was pretty much done with taping but I knew I had to rake a better light across the surface before I was comfortable with putting on primer paint. I had been using a quartz work light to rake the surface but I think it's beam was too wide. This is what I saw after the last coat (before sanding)
So I took out a flashlight with an adjustable beam and :surprise:.
I still have a lot of work to do! And I don't think sanding alone will make it all better.
So I was thinking...
Should I thin the topping compound a bit more so it will flow better?
Should I go to a wider taping knife? I have been using a 10".
Should I just put a small amount in the mud pan and clean it between refills?
Should I run the knife side-to-side instead of up and down?
In the past, when I have done much smaller jobs, I would take a foam sanding block and feather it out. It was all I knew. Now I'm thinking there has to be a better way where so much sanding isn't necessary.
I was thinking back about watching tapers on the job but I never really studied what they did because I had my job to do. But it seemed to me they just did a light sanding with a pole sander and they were done. Of course they had all the best taping tools and a ton of skill. :vs_cool:
That's just bad technique.Can't blame it on the mud.With that said ,how much did you thin the mud?
I usually use a 12" knife,sometimes a 14 , for the slick coat.
Do not try and slick coat running side to side.
I don't see any indication that your mud was dirty.If it has crumblies or something else in it it will leave a vertical line.
Try taking a 6" knife on about a 45 degree angle with quite a bit of pressure applied and drag it acrossed the high spots.It will take them down and save you lots of sanding .May have to adjust the angle a bit but you'll get the hang of it.
We do our best to do clean flat joints and then scrape off any ridges in this manner.Then just do a light sanding on the slick coat.
I thinned the mud, probably thinner than bazooka consistency, and that made the difference. I also put less mud in the pan.
Using a 14" knife I was able to get a very smooth coat down. I think part of the problem is the topping compound dries pretty quickly.
Anyway, my frustration levels have dropped. I'm expecting to start the primer painting tomorrow. :vs_karate:
1 - 6 of 6 Posts
