i just figured out what these switches are called, "momentary" switch
here are the details on the switch its self....
Toggle SPDT Center-OFF Momentary
• Conforms to NEMA
I have a roll-a-shutter, its an out side shutter that lowers over the outside of a window, mine are electrical.
first off Ive done this a few years ago and cannot remember how i did it, that being said im trying to wire in the switches that go with this shutter, the switch looks like a regular residential toggle switch, how ever these switches are normally off, push the toggle up to raise the shutter, release the toggle and the shutter stops push down on the switch and the shutter lowers...
the shutter has 3 wires coming from the shutter motor, red, black and white. the switch has attachment screws for 3 wires, a screw in the middle (for power) and one at each end (up and down)
the switch is marked with, L1 A1 B1, its a P and S switch 1/2 hp 120 vAC
2hp 240v AC Cat 1250 15 amp
sure would like some help, thanks...
Single Pole General Purpose AC Switch
• Toggle SPDT Center-OFF Momentary
• 15 (1250-I) or 20 Amp (1251-I), 120/277 VAC
• Industrial Grade
• Color: Ivory (others available)
• Fiber terminal insulation barrier standard
• Thermoset top, body and toggle
• Steel strap
• Limited 10 year warranty
• UL/CSA
• Industrial Grade
• Steel strap
• UL/CSA
Line Voltage Characteristics
Contacts: oversize silver alloy for
long life and better heat dissipation
Termination: clamp-type terminals accept up to
#10 CU wire, back termination also
Physical:
Mounts in standard one gang box
Operates in any position
Electrical:
120/277 VAC
Maximum Amp: 12 (1256), 16 (1257)
Motor Loads
1250-I: 1/2 HP - 120V, 2HP - 240V-277V
1251-I: 1 HP - 120V, 2HP - 240V
Fluorescent, tungsten and resistive loads:
full rated current capacity
Operating Environment:
Location Interior Space
Operating -40° to 75° C
Temperature
Temperature
Relative 10% to 95% Non-condensing
Humidity
Humidity
Atmosphere Non-explosive, Non-corrosive
Flammability rated UL 94 V2
Vibration Stationary application
NEMA Level A
NEMA Level A
Testing and Code Compliance:
UL listed
CSA Certified
• Conforms to NEMA
