Hi everyone. I have a question about what to do about an old VCT floor, and I could not find a satisfactory answer after hours upon hours of searching, so . . . I hope this is not too long:
I have an old VCT floor in the basement of my 1938 home. I do not know the age of the VCT, but it is a 12x12 Armstrong Standard Excelon tile - I found a box of leftover tiles in a closet. The floor has water damage and the tiles have buckled after several/prolonged exposures. I do not know if the moisture problem's source has ever been through the basement slab (or perimeter), but I do know that some damage resulted from overhead waterline leaks, as well as spillage from a dehumidifier with a faulty shut-off sensor.
So After cleaning up the latest spill, I decided to peel back a corner and see what is beneath. I could see water coming up through some of the joints when I stepped on buckled areas, so what more damage could I do? The corner of the tile broke away, and I found a beige/brown adhesive over a backer board of some kind. The backer is black (or discolored?)on it's top surface, and green throughout its 1/8" thickness. It is rigid, and contains shiny particles that glitter in the light, and the board snaps rather than crumbling or folding. The bottom of the board has a rough dark brown coating too. I don't know if this is a manufacturer's coating or an underlayment that became fused to the board over time? Beneath the green board I was surprised to find a dark brown or blackish granular material, about 1/2" deep, over the concrete slab. Is this a deteriorated backer board, or some kind of leveling system . . . ? I have no clue what it could be. I thought I would find thin, troweled, black cutback adhesive, which is what I see at the unfinished edge ( uncovered threshold at my utility closet), but it lookes like the edge system is different from the floor area.
So my main question is this - do I need to worry about asbestos? The wood paneling decor of the room leads me to believe that the room was finished around the time when manufacturers made a transition away from asbestos. But I don't have a date for the installation. So I am not sure how to proceed with this - for now I am leaving it alone. I also have an armstrong 12x12 ACT ceiling stapled to the underside of the floor joists in this room - also with water damage and in need of repair; I learned that these may also contain asbestos and am concerned about that, but I'll leave that for another thread. Any help is greatly appreciated. Thanks.
