Greetings,
I installed a Reliance manual transfer switch kit model number 31406CRK a number of years ago shortly after the huge outage in 2002 we had in N.E. U.S. I also have a Dayton 3W737C generator which I recently discovered is bonded which I never even knew until reading recently about bonded & neutral floating generators which made me wonder what I have since installing the transfer switch. So I went back over the transfer switch install I did many years ago. I realize I may need to unbond the neutral on the generator so I'm working on that. But I'm wondering if the transfer switch was wired correctly, I watched the video. Only issue I had during the install was that there were no open Neutral/Ground spots in the Main panel. I have a subfeed panel next to the main panel and there were open Neutral & Ground spots to wire the transfer switch green & white wires into which brings me to my question can the white neutral wire & green ground from the transfer switch wires be wired into the sub panel buses? Or should I find a way to change this & put them into the main panel on the neutral/ground bus bars. I have attached some images for input thank You
