I have an ancient 1987 Payne heater and separate BDP coil installed in the crawl space. To change the filter I have to crawl on my belly below the ducting to get to the other side of the heater. The previous owner just installed a 20x25x1 filter and it's sticking out of the side of the heater/air handler and presumably sucking in the dusty crawl space air. I searched but was not able to find the model number (Payne 376baw048095) anywhere to get the correct filter. I measured the length of the filter opening at 21.5".
Several questions:
1. what filter size would be appropriate?
2. can I relocate the filter to a more easily accessible location?
I've attached a picture of my return housing as a possible location for the filter. Maybe I can cut the return "housing" (I forget the proper name) and install a frame for the filter. There is only one return location and it's installed in a hallway closet with an opening cut out of the closet door and another return duct in the living room adjacent to the hallway closet (stupid design!!). The house is 2000 sqf.
Thanks for your help.
Several questions:
