1 - 6 of 6 Posts
I have a 1940s house and the walls are all plaster. Underneath the plaster finish, there is a rock mixture and then there is some kind of board which looks a lot like modern drywall. It's about 1/4" thick and in approx 2' x 4' sheets. Other houses in the neighborhood have the old time wood lathe under the plaster. What kind of board do I have? Anyone know?
Super Moderator
It was the transition between wood lath and drywall. It was called rock lath and most that I have seen was 16"x4' sheets. It replaced the wood part of the wood lath and plaster walls. It went up much faster than nailing all the small wood strips.
Mold!! Let's kill it!
What you have is "rock lath". That was the name for sheet material that was applied to walls and was then plastered over. A lot of 1940s-50s-60s buildings used it before drywall became popular. Rock lath was originally a brand name for plaster board. It is normally 16"x48"x3/8", but there were other variations. Rock lath eliminated the base scratch coat that got applied to wood lath.
Discussion Starter · #6 ·
thanks
Thanks guys -- you're exactly right. It was 16"x4'. I'll tell ya --- that plaster & rock lath is saving me a little money on heating and AC since there is no insulation behind it! Just a little money though -- better than plain drywall.
1 - 6 of 6 Posts
