OK to put latex satin over latex semi gloss?
1110 Views 3 Replies 4 Participants Last post by  Grants Painting
Just wondering- the semi was done years ago. Guess I can lightly sand walls to help, eh? Hope I dont have to prime.....
Thanks
Noquacks, it depends. I usually scuff sand somewhat aggressively to give that Satin something to bite onto. Wipe off the dust and maybe test a small area to make sure of adhesion. If you see a separation of paint then you will have to prime with a bonding primer.
Thanks
95% of the time, this will work just fine, you might have to do a little more than lightly sand though.
Satin over Semi-Gloss
As long as you are using a good quality paint you should be fine with a light sanding. In fact every wall that you paint a satin or above on should be lightly sanded anyway.
