I'm diagnosing an open fault on an overhead radiant heat system. 240V, 20A circuit, SPST thermostat. I've already opened up a small hole and have full access to the overhead system.
I'm getting an infinity reading on ohms, but I located a break with my toner and repaired it, and STILL no connectivity.
I'm using my toner, and I can tell there is some kind of connection between the t-stat drop and where I found the break (loud LOUD tone, same as if I touch the toner to the other end of the wire), but when I use my long lead to test DVOM continuity at that point I'm still getting infinity.
So - with the wire exposed I get 100% tone continuity to this spot, but when I use my ohmmeter I still show infinite. Frustrating.
Help!
Help!
