Hello,
I have 10 year old Rheem oil furnace. My oil tank (I think it is 250 gallons) is 25% full. Two days back the furnace stopped blowing hot air. It looked like the blower in the furnace was working but the furnace was not ignited. So there was only cold air blowing from all the vents.
I called the technician and he replaced something (probable nozzle). Then the furnace worked fine during evening hours but then again next day morning it stopped working. So I called the same technician again, he came and checked the furnace. He pressed the trip button and restarted the furnace. It fired up this time and it started blowing hot air. After checking few things he said that the oil temperature was very low and so furnace did not ignite. the temperature on Oil tank was 29 degree F. He checked the wall temperature and it was 22 degree and around the oil pipe (leading to furnace) it was around 27 or 29.
Now after few hours of furnace working it is again blowing only cold air (in between it went through couple of cycles of on/off based on temperature setting).
So is it true that at 29 or probably 27 degrees the oil becomes thick and so oil furnace won't fire up? It is likely that during night hours the temperature around the oil tank might be lower then 29 degrees.
Please help.
Thanks
Please help.
Thanks
