I have an oil fired well mclain with baseboard heat. Woke up this morning, turned the thermostat on, heard the click but no heat. So far the only way I can get the pump to cycle water is if I use jumpers from the 120v input to the pumps inputs in the control box. Everything else works fine. I have hotwater in the house. The honeywell box is not even 2 years old. I took off the wires in the thermostat and crossed them and still nothing. I then used jumpers and crossed the thermo leads in the box and still natta.
