Remodeling bathroom. Slab! Pulled toilet to remove old tile and install new toilet flange at proper height once new tile is installed. Discovered that original flange is brass, soldered to lead sleeve. Lead sleeve 4” tapering to 3” and glued into 3” PVC closet elbow about 3” below slab. Lead is male; PVC is female. I want to install an offset flange. I’ve removed the brass flange and now just have lead w/ rough edge protruding through slab. Probably should have left well-enough alone and kept original brass flange, but.... BTW, it was not attached to the slab in any way. Guess the lead sleeve was holding it in position.
Question(s): Any way to remove the lead sleeve without damaging the PVC? If I could pull it out, I could glue an offset to the existing 3” elbow. If lead can’t be removed, is there any sort of offset that will seat into the lead sleeve? Thinking of those flanges with the expanding gasket or the ones with multiple rubber(?) flanges that push into existing waste line/elbow? Really don't want to have to solder a new brass flange if it can be avoided. Do they even make brass offset?
Probably won’t be much clearance between anchor points where flange attaches to slab and drain. If I drill for anchor bolts, will I bust up the concrete? Is there an adhesive that would work?
Thanks.
Thanks.
