Maybe this should be cross-posted in the electrical section as well.
I went looking for an Off-Delay Timer/Switch for a bathroom exhaust fan. I discovered the linked switch which operates both the bathroom Light and Fan. The light turns OFF as soon as the switch is opened, the fan stays ON until expiration of an owner selected time delay. Unless the switch is ON for less than 10 seconds, in which case both the Light and Fan turn OFF when switch is opened.
The switch can also be programmed to run the fan for a selected minimum time duration each hour.
https://www.energyconscious.com/aircycler-smartexhaust-toggle-switch-almond-se1-a.html
Anyone use this device or another similar? Seems pricey at $65 each, but also no need to install a larger box to accommodate two switches. Anything else on the market?
