1 - 20 of 26 Posts
There's a GFI receptacle on the exterior of my house. The wires running to it are not like anything I've ever seen. I believe the wiring runs into my attic, except when its in the attic it appear to be old rubberized NM-B cable (both the sheath and the insulators). So without further ado... Here's a photo. What type of wire is this?
I'm on the East Coast of the US, and have not seen anything like it either. The house was built in 1947. I've seen wiring in the house that seems to range from armored with rubberized insulation, to aluminum wiring, to modern stuff. So figure it could be anything made in the last 70 years.
· Super Moderator
That is still available at the big box stores on rolls. I believe it is for direct burial. I have never used it.
Jim, so you agree with sgip2000 that its older UF? Any issues with it? What bothers me is that it appears to be connected to some old rubberized NM cable somewhere in the exterior wall (sandwiched between plaster on the inside and two layers of siding on the outside) -- with insulation in between. And to make matters worse, there are windows above it, so it has to go horizontal (through studs)... So if its stapled in, I'm done....
· Semi-Pro Electro-Geek
I'm with KB - I think it's submersible pump cable. The colors are different than usual, but they're also not normal for any other use. The construction looks exactly like pump cable.
Discussion Starter · #15 ·
joed, I don't see any cable marked with white either. I thought that was a bit odd. I can't see why a cable intended for 240V would be an issue at 120V though (in fact, I didn't know there were cables intended for 240V vs 120V). Regular NM-B cable is rated to 600V. The stranded nature is kind of odd though.
There was a cover over it that I removed that consists of a rubber/foam gasket and a metal cover with a spring loaded hinged door (with rubber/foam gasket on the door). I removed the cover so that I could inspect everything, its going back on.
If I can figure out how to replace it, I'd love to, but like I said, its not exactly in an easy to get at place.
Anyway, thanks for the feedback.
I feel your pain !! I wouldn't worry about the wire as it's fine for a 120 duplex but if it were me.... I'd splice a new 12-2 (in a J box) and run it down a stud space beside the window and then just pull the old receptical and put a cover plate over the old box. I don't think you'll have much luck running a new wire to the existing location without some plaster removal.
Good luck !!
Discussion Starter · #17 ·
I have an unfinished basement. If I were going to replace the line, I'd probably drill a hole from the basement, up, fish a 10 gauge solid wire through it (I doub its more than a 2 foot run through the wall), and then pull some new 12-2 through that. Anything else would be a royal PITA.
Did I mention that I have two layers of siding? One is nice, easy vinyl, the other is one of the following: stone, stucco, or asbestos tile)-- NONE of which I want to attempt to go through.
If I were going to replace the line,....
It is not listed for the purpose, and never has been. So, it is a code violation. Opinions of how hazardous it may or may not be, don't count.
Your safest course of action is find the box where that well wire starts, and disconnect it.
Then you can debate whether you pull new wire to that box, or install another box elsewhere.
Discussion Starter · #19 ·
Thanks for your advice. In case you didn't notice, the box is inside an insulated wall with plaster on one side and something very nasty on the other -- I don't know where exactly it is and don't know any non-destructive way of finding it. It would be much easier to run a new line than to find the place where the well wire starts.
My house is 65 years old, there are tons of things in it that do not meet current code. For example, I don't have a single GFI circuits inside the house, I have no AFI breakers. I have wire in there that does not have ground. I'm doing my best to correct what I can, but I'm not going to go crazy to disconnect a wire that I have no reason to believe has failed and is protected by a circuit breaker.
What is the catastrophic failure mode? The wire insulation fails, shorts between hot and ground or got and neutral, the circuit breaker fails to open the circuit and the insulation catches on fire from the heat? Pretty unlikely. The breaker is either Square D QO or Cutler Hammer CH breaker -- both of which have a pretty good reputation imho.
1 - 20 of 26 Posts
