I had a couple of questions regarding receptacles on breakers as follows only looking for international building code answer no further local code to follow also none of lines have a gcfi receptacle on the line.
On a 20 amp afi gcfi breaker how many receptacles can you have (new square d qo without a pigtail breaker)
How many receptacles are allowed on a afi breaker 20 amp.
how many receptacles are allowed on a gcfi breaker 20 amp.
· Property Mgt/Maint
From my understanding there is no limit on qty of receptacles per circuit. But proper planning and knowing the total amperage draw of what the receptacles will be used for should be a limiting factor.
The electricians will stop by with clarification
Is there a difference if you use an afi with a gfci receptacle because in that case I had heard I think it was 4 after gfci receptacle. I didn't know if the rules changed with using breakers instead.
· A "Handy Husband"
Nope, you heard wrong.
