Hello,
First time homeowner, and very green with all things plumbing. We had some plumbing work done about a month ago to replace some pinhole patched copper piping and shoddy supply pipes as a proactive measure. AquaPex Pex-A was used for some of the supply piping along the basement ceiling. This was done about a month ago.
I've noticed a few things with the piping that are curious to me, and was hoping to get some additional opinions on them. These seem to be occurring on the hot water supply lines:
1) One stretch of the Pex has what I can best describe as a long, thin, raised bump on the exterior. It almost feels like a scratch. It runs half the length of one side, and then seems to run the length of the other half on the other side. See pics below. Is this likely to be a defect in the piping? As of yet, there is no leaking.
2) Much of the Pex is staining yellow, or flat-out turning yellow. I've heard mixed opinions on this. Is this likely to be damaging the piping? Caused by hard water? We had out water heater flushed last March and was going to do it again come Spring, should we even wait that long?
3) The hot water supply line sags and is quite wavy. I understand Pex will contract and expand, but the sagging is very noticeable. It's about three inches down from the ceiling. Plumber offered to add additional support if necessary. Is this much sagging normal from Pex?
Pics below... TIA for any insight for this newb!
