1 - 12 of 12 Posts
what do you guys think of this? is this DIY possible? i am referring to the slide, not the pool. seeing this pic made me think about having this coming out my window, with a landing pad on the ground. i am crazy........right
· Retired Moderator
Is that going to be the exit for door to door salesmen and other unwanted visitors?
Your neighbors will love it---I say ,"Go for it!"
You would need to design it for a landing pad, you would hit to hard with this style. The fireman pole would be easier to install. I would make a model from pvc first then send hamsters down so you can find the set up that works best. Probably want to make little outfits for the hamsters first so you will get a more accurate idea how how the slide will function.
· Retired Moderator
Man are you in trouble now, PETA is going to eat your lunch.:laughing:
· Wire Chewer
I think it would be awesome to do, but make it so it goes just slightly over your car, and see if you can program your remove to open the driver window. That way you can land right in your car. Shovelling is overrated. Just get in and drive! :laughing:
1 - 12 of 12 Posts
