I just purchased a new 40 Gallon Whirlpool Electric Hot Water Heater from Lowes, because the Old Whirlpool 40 Gallon Heater was not producing enough Hot water. Now the same thing is occurring with the new heater.
The house has 1 bathroom with two Adults taking showers in the morning, each adult takes about a 5 min shower using a standard shower head 2 1/2 gallon per min. The hot water ends in about 7 min. I have checked to make sure the cold water in, and hot water out pipes are correctly connected to the heater and the temp is set at 110 degrees. I also had an electrician check the voltage...still no luck. Any ideas and/or troubleshooting suggestions would be so very appreciated!
Very strange that mu plumber and electrician cant give me an answer about what could be cuasing this issue...the same issue was occuring with the old heater ...thanks!
