Hi,
I want to tie into my house plumbing for hot and cold for an outdoor shower in Vermont.
I orginally purchased Sillcocks for the job.
I will install the sillcocks and then plumb in the shower on the outside
and then use hot water hoses for quick connect/disconnect each fall/winter
making sure all the water drains out.
or Should I solder in shutoffs 2 feet from the sill on the inside angle it down slightly, run it through the sill add in a low point drain shutoff
and then do the same connect/disconnect?
I guess the issue is drilling a 7 inch 1 1/4 hole as opposed to drilling a smaller hole to slip copper pipe through.
Thanks!
Thanks!
