1 - 20 of 24 Posts
Wood Floor Flooring Hardwood Wood stain
Found this in the basement window frame of my 10 year old house. The window is above ground. An indentation from one of the horseshoe-shaped shims is visible as an indentation on the wood under the corner of the window.
Is this normal for its age, is the window damaged, was it improperly installed, or something else?
Can I do anything to curb it?
Seems like the window is not properly installed, as i can see, the damage gets worse as you approach the window, so its probably leaking
JUSTA MEMBER
Water damage indicated a leaking seal.
Probably around the window.
More investigation is needed to find the leak.
ED
JUSTA MEMBER
Can I find the issue without pulling the entire window out? What should I look for?
Have a helper with a garden hose, LIGHTLY put water around the outside of the house, near the window, or set up a sprinkler to spray LIGHTLY around the area.
Be inside looking for where the water is coming from.
This might need to remove the inside trim to see better.
Sometimes just removing the trim, you see DAYLIGHT coming in around the window.
That would be a leak.
And sometimes it's the roof, and running down the inside of the wall, to appear under a window.
GOOD LUCK.
ED
To close of picture on outside to see what it is like. Does not look like it was ever sealed or finished on the inside. Just folding house wrap in on the opening is not practiced by a lot of guys anymore. Suggest spray water on outside to see if water comes in somewhere, start low work up .
Naildriver
Problem one is the siding was not cut back to accommodate the brick mold. The windows need to be set back in the opening at least an inch if not more. Then j channel applied around the brick mold then the siding reinstalled to fit. This was not the way to install windows. I am surprised that is all the water intrusion you had.
Problem two is there is no flashing over the top of the window to prevent vertical water from infiltrating.
Most builders don't install windows or doors correctly,
and I can see that yours has been done wrong.
Housewrap should never be pulled into the rough openings like that.
Anytime I see housewrap folded into a rough opening like that, I know
it was done by ignoramus hacks who don't bother to read instructions.
You will never be able to keep water out unless it's done right from the get-go.
JUSTA MEMBER
At 10 years old, is the builders Warranty still in effect?
If so, get their DUM-BASS out there, and get a free fix, before the warranty runs out.
ED
Discussion Starter · #14 ·
Unfortunately not. It's just over the ten year mark.
I tried to get a blown seal fixed in another window; the builder pointed the finger at the window manufacturer/installer, which pointed the finger at another window manufacturer/installer, which went back and forth over and over again. It was complete bullshit.
JUSTA MEMBER
I fear this is going to get costly.
Too bad about the builder being a " Dump and run" type.
ED
My brother had a similar issue where his community identified problems across all the homes built by the same builder and under pressure the builder stepped up and fixed all the homes which was just after the warranty expired. It must have been a fortune to fix.
Naildriver
I don 't look at as a "warranty" item. IT was sloppy building. They should be held liable for fixing it.
JUSTA MEMBER
You are correct.
Unfortunately, "SLEEZY" builders Weasel out often, because, if it is not caught before the warranty expires, they are " off the hook", legally.
ED
retired framer
We do not know that this is any more than condensation.
Naildriver
Neal, look at the pictures in post #7. The siding was never cut back to accept the full window to it's normal depth. It should never be protruding like that. Pictures of further back and at an angle may prove beneficial.
Reactions: de-nagorg
1 - 20 of 24 Posts
