I have an Arcoaire heat pump, installed 1989, the type that has the air handler outside with the compresser, all self-contained. It has a propane power source.
It was working fine, then one day it just up and quit -I mean dead. I checked the t-stat first, and tried touching the green wire to the red wire to see if the fan would start. Also tried the yellow wire to the red wire, same result. The circuit breaker works, and the outside wall-mounted fuses are good. Outside, I went to discharge the capacitors with an insulated screwdriver, but there was no spark from any of them. I don't know if there is a condensate overflow switch, being that it is an outdoor unit, but I went ahead and cleaned out all the debris under the compressor and condenser.
I am sure there is something somewhere on the heatpump that could cause this, but I don't know what it would be. Contactor perhaps? Transformer? I doubt all three capacitors would go bad at once, and I don't know if that would cause this effect anyway.
Someone help please -I want to impress my wife.
