1 - 15 of 15 Posts
I frequently use a non-contact voltage tester wand to quickly tell me if an outlet has power. Usually I have to slide it in a slot to get a reading. On one of my rental properties I used it on some upstairs outlets, and it started beeping and the light came on when I was about 1 inch away from the outlets. In the downstairs outlets I have to slide it in as usual to get a reading. Does this mean anything?
I used a volt meter, and the upstairs outlets read 114 to 115.
Discussion Starter #2
There are no replies so can I assume it does not mean anything? This is the first time I have seen this happen, and it ONLY occurs in the upstairs of this particular house.
Semi-Pro Electro-Geek
Totally normal behavior.
Super Moderator
You can make one beep by rubbing up and down your sleeve.
Reactions: plummen
Master Electrician
mine goes off randomly in my pants pocket while i walk at work :laughing:
Super Moderator
Reactions: k_buz
Master Electrician
both :thumbup:
Discussion Starter #10
I have used this wand for a long time in many houses and it ONLY happens in this house in the upstairs room.
Non contact testers are prone to go off for no reason at all. Use a plug in tester for outlets, a wiggy for other testing. Non contact are not useless...they tell you there is power....somewhere.:laughing:
"Useless" might be a little harsh. If anything they are overly sensitive...which means if you can't get it to beep, chances are the nearest voltage is 1/2 mile away. Yet, voltage (or lack of) should be verified with something more precise if the work involves handling potentially energized components.
Master Electrician
they are particularly "not usefull" for testing unbalanced loads on neutrals. probably why most shocks come off the neutral.
I thought the neutral conductor was used "after" the load?
Mad Scientist
Just for S&G, you might want to check that particular outlet for a hot ground, or energized metal box. I've seen exactly what you're talking about in a house that had some outlets wired with a bootleg ground and reversed polarity. On the normal outlets, I'd have to get the probe at least *near* the hot slot on the receptacle to get a beep. On the outlets with electrified grounds, the beeper would go off anywhere near the receptacle.
Always verify strange readings with a voltmeter, using an extension cord plugged into a known good outlet as a reference point if necessary.
1 - 15 of 15 Posts
