So I have been replacing old plugs and switches in my house. Being my breaker panel is not labelled and that I didn't want to shut power to entire house, my process has been to trip breakers one at a time while my wife uses a NCVT until power is off (it stops beeping). I then change out the plug switch and repeat. I was about 99% done until I got to my last plug and switch (they are in line of each other). This time though the tester kept beeping even after I tripped every breaker in the house. I then went to turn the main breaker switch off (no power to entire house), and the tester would still beep at this switch and plug. I got my multimeter and conmfirmed no power. I even got a power drill and plugged it in and sure enough no power. But tester goes crazy if I put it near the plug or switch. There is also a light wall scone near the switch and the tester goes crazy there too.
Any ideas why the tester gives me a false positive? Thanks
