1 - 16 of 16 Posts
Nope, can't do that unless you want to go buy a whole bunch of GRLs (Groundable Lock rings) and tag them with your ground wire. all metal parts must be bonded together.
Cheaper option, go buy a bag of the plastic type connectors
· Banned
Care to cite. They have been used in that way more times then anyone can count. No ground lug needed, because the box is Plastic not metal.
NEC states "Not Required", not "Illegal", when the NM clamps are used with Smart Boxes and the PVC or Fiberglass boxes. That means that the NEC considers it personal choice if you wish to use the NM or MC/AC clamps on that particular style of box.
· Banned
I'm with Greg on this. Keep in mind a plastic 1900 box used for devices would get a metal plaster ring, wouldn't it? How would you ground that?
I would, unless you use a Smart box after throwing up the drywall and go back to cut the holes.
I wished that I used a metal box for the light abobe the vanity, when I did my bath remodel. Did not notice a twist in that 2x4, until I put up the Green board. Used metal for the box for the three switchs.
· Super Moderator
I know this will not be answered, but, Greg, can to cite the allowance for this? Please provide the code article.
Could that possibly be a Canadian regulation? I've never seen it in NEC codes.
1 - 16 of 16 Posts
