I have a low output drilled well which supplies a cistern tank. The level in that tank is controlled by two probes and a B/W (Magnetek) liquid level controller. Although it works it has always buzzed to some degree. Of late it was getting particularly loud, like obvious from 30' feet away in my basement. I removed the contacts and cleaned them, also tried a spare controller. No improvement. I also cleaned the probes today as well as the ground rod in the cistern. No change.
Since this water control system is about 30 years old is there a more modern, electronic version of this relay set up that would be quiet and not be insanely expensive? Or other advice? thanks..
