First off, I want to thank all of you for your advice. I will certainly come here with any more problems because I try to do most of the stuff around here while my husband is at work so he doesn't have so much to worry about when he gets home. No, I can't clone myself.....
The problem ended up being in the light switch. Both of the ground wires were actually wraped together and grounded out somewhere other than the switch box. When I re-wired the switch, finding a black wire on the screw, I ASSumed that it was the ground wire and put it to the ground screw, then the black and a red wire (go figure) I attached as they had been. Turns out the second black wire I had put on the ground screw was the hot wire. Since it is grounded somewhere else there wasn't anything on the ground screw. Once both hots were connected, one in the hole and one on the screw and the red in the other, it all works.
That is just amazing. It did help me to realize that power was feeding from one into the others and I knew it had to have stopped somewhere. The only other one was the light switch, which I knew had power because it was working. Wow.
Thanks everyone!
