The short answer is an open neutral and some load that is plugged in or switched on.How would you get 120 volts from white to ground?
How do you figure? There is no voltage on the neutral to hot. But voltage on H-G and N-G.Open neutral. No doubt in mind.
If the garage is detached the buried cable could be damaged.
The full voltage is read thru the load on the neutral because without a closed circuit there is no voltage drop.That doens't explain why the hot is dead or why he's ready 120 on the neutral. If it's being fed from another device it should be lower than 120.
You don't understand how electricity works. It is not being fed from another device. The voltage is passing through a device on the circuit.That doens't explain why the hot is dead or why he's ready 120 on the neutral. If it's being fed from another device it should be lower than 120.
I do, it's symatics "fed" "passing through", whatever. The fact is even if it passes through a device it will have some voltage drop. Both will not read 120v. In fact it's suspect that it's reading 120. Most often it will read between 116v-118v.You don't understand how electricity works. It is not being fed from another device. The voltage is passing through a device on the circuit.
