Ok, here is the scenario:
I replaced all the receptacles with new ones (nothing fancy, just regular ones with a ground) and the light switches ([1] 3-way and [1] 4-way and [2] standard single pole switches).
The dining room area has one of the standard single pole switches and I replaced it with a known working (new) switch, nothing. So, I moved onto the living room just to finish up before turning on the power and the three and four way worked as designed by turning on and off the ceiling fan and the light. The reason I needed a four-way is there is a common wire from the four way to a standard SP switch that powers the front porch lights, once again, all tested fine when I put the power back on EXCEPT the dining room. I went back to buy another new single pole switch just to make sure; however, this time not only does the dining room light not work the living room, front porch light and three receptacles in the living no longer work! These ALL tested working with a multimeter right before I left to buy another switch.
I pulled the wires out and tested at each switch location and none of the wires are "hot". I am stumped?
I replaced the breaker just to be sure and to no avail. I made sure to replace each switch one-by-one replacing the wires as they were originally setup in the old switch so there would be no confusion.
Any ideas?
Any ideas?
