Bathroom is plumbed using no-hub cast iron. The main stack is 4", which is reduced to 3". So I have a 3" closet bend. The only no-hub cast iron toilet flange my plumbing supply has is one that fits inside the 3" bend and then expands to seal when the bolts are tightened. My problem with this oslution is that it effectively reduces the 3" diameter of the closet bend to 2 1/2." With a kid and a wife flushing G-d knows what down the toilets, I would prefer to have a full 3" diameter drain.
Can I just use a 3" street PVC closet flange and use a no-hub coupler to attach it to the cast iron closet bend? Any other options in this instance?
Thanks in advance for the help.
