7/1/2011 purchased a 110 year old home (historic registered) was re-piped in 2007. 5 bed /4.5 Bath . WH was a single element 40 gal. I thought that was the reason the luke warm water temp was from undersized unit . I purchased and instasallled a Nearly new WH Lowes energy smart electric to replace , plenty of heat at the presure release brass valve, and on the iner- tank skin extremely hot to touch. so this along with a volt and ohm meter with no power on and the wires off the elements the elements tested good, with ohm meter. as well with it hooked up the volt meter has 240VAC at the elements. How ever no Hot water at any sink or shower. I shut all the supply valves to each accessible device and tried the sink in an adjencent room from the laundry where the WH is located no hot water what should I do next ? ( this is a 3story with crawl space frame house built 1901 in Central Florida)
Gibone:wink:
Gibone:wink:
