1 - 6 of 6 Posts
I own a home that is 5 years-old. I lived in it since it was built. I noticed that there was no hot water coming out. I shut off the main valve to the house and took of the single handle. I then took off the guts inside of the fixture, had my son turnt eh water back on and noticed that the water was comng out off only one tube and the second one was dry. The house is relatively new and has no galvanized pipes. I also notice last night that the sink in my garage has no hot water as well. The rest of the house is okay. Can anybody help me with this and possible trouble shooting tips or possible solutions? Thank you.
Will,
if it's only the shower and garage sink without hot water, and the other sinks are ok, there is a valve shutoff somewhere on the hot water side. Start tracing the hot water from the hot water tank outward and look for any shutoffs. They shouldn't be hidden behind drywall, especially in a house that new, unless somebody finished off the basement ceilings. Let us know what you find. If it were just the shower, I would say to check and see if your shower control valve has built in stops. they look like a small brass slotted screw. They move a quarter turn to open of close the water.
Mike Hawkins:)
You may want to replace the old valve cartridge. search how to replace cartridge in youtube for instruction. Are you using well water? if the water is too hard, or defect of the cartridge, the holes will not line up, you won't get hot water, especially.
First thing, remove the cartridge to see if you get hot water out. if yes, buy a cartridge from homedepot about 10 bucks. this will save you at least 100 dollars from plumber.:thumbsup:
Thank you everyone for your help in this matter. Otherbill, I took your advice and the valve was already fully open. So, I closed it back up and open it again. Still no hot water in the master bedroom tub. dongdong1, I took off the old valve cartridge and there is no hot water coming out. It is regular city water and yes, the water here is hard. Mike, I saw the built in stop and it is difficult to turn. Now, when I took the cartridge off the pipe that is on the side of the built in stop it works properly. The pipe on the other side of that one is the side where there is no water. Now, the built in stop was inside. If I turn it will this loosen any blockage in that pipe?
Will,
I am not clear on your description. There should be a stop on each side. On the side you aren't getting any water out of the pipe, did you try and turn the stop? It's only a quarter turn. Can you take a couple of pics and post them, that would help.
Mike Hawkins:)
1 - 6 of 6 Posts
