I am not an electrican so please forgive me if I incorrectly identify anything discribed in my question. I have a condo in a high rise building that was constructed in the early 80's. All of the wiring is two wire BX or AC flex cable with no ground wire. The circuit panel is supplied with two hots and a neutral, no main disconnect, and no ground bus. If I were to add a new circuit to the panel (using AC flex cable with two wires plus ground), how would I properly attach the ground wire to the circuit panel. Thanks in advance
