my newel post is broke at off at the top (were you would hang your coat) split down 2 sides and broke off on one. How do i repair it? O r do I just need to replace it?
Glue it back together.
Post some photos.
Yep, if it is painted, Titebond II or similar makes a joint as strong or stronger than the wood. CAREFULLY match the parts, apply glue with a small brush or force it into cracks, then use finish nails to hold the parts until dry. Sand edges smooth and paint. If stained, the repair will show, no matter how good you get the joints. Then is is best to replace, but that is not a simple job.
Too Short? Cut it Again!
Guerilla Glue will work too.
You will need some clamps with whatever glue you use.
Concerns me this fell apart on you all at once though. Any extraordinary forces put on it lately?
