Hi,
Last year I replaced the upper stairs in our split-level entry home. They were previously carpeted and once removed were obviously not strong enough for the proposed wood stairs (stringers insufficient and thin plywood treads and risers). I replaced them with a triple 2x12 stringer and 1-1/4 ply treads and risers.
I'm just getting ready to finish it off which involves removing the knee wall and old railing (see the last pic. BTW, the outside has been re-sided, new windows, door etc..) but I'm not sure of the best method to complete the job. I have a box newel post and iron balusters for the job.
1. Due to the front door swing, I won't be able to being the newel post much farther out than the last stair. I'll probably only be able to push it out as far as the bullnose on the treads. Reasonable?
2. The stair width is 39" and I'd like to maintain as much of this as possible. Would it be better to end the railing at the top of the knee wall and put a full railing opposite the knee wall or have a single railing along the knee wall and jog it and continue it up to the top of the stairs?
3. The baseboard around the house is a 5-1/2 craftsman style with plinth blocks and coroner blocks. What's the best way to continue this trimwork down the stairs with the skirting and knee wall? I have some small 1/8" MDF for the skirting.
4. Would it be better to eliminate the knee wall and build out the treads? I should have enough bullnose for the returns.
Any help or comments appreciated!
Mike
Mike
