We have a 1993 York 3.5 ton split unit in southern OR. We moved here in 2007. We would like entire new duct under the house as home inspection in 2007 found it broken apart in two places plus other issues. Seller had it fixed. It is CertainTeed fiberglass ductboard. How long it was broken is unknown. We have had a blower door test which showed lots of air leaks: can lights, outlets, ABS plumbing, stack vents, etc. Also floor registers and air return have gaps. Loose cellulose insulation in the attic is entering house and collects as fine dust.
We would love to get a new split unit with the new ducting. Can't afford the $16K to $20K bids we have had for 16 SEER, variable speed A/H, new ducting, 2 zones, additional air return (we have one) and a super-duper whole house air cleaner. We are all-electric and our power bills are $400+ in winter.
Two HVAC licensed contractors did Man J and D for their bids. 4 others quoted for 3.5 tons with no new ducting. We are 2200 s.f., single level. One bid was for 5 tons (or 2 tons with zoning). Other bid was for 3 tons, no zoning.
I wanted all new duct work and an additional air return, to run with our existing unit but that has been pronounced dumb until a complete new split system is installed with various calculations.
Current thinking is this: blower door and duct blaster test followed by air sealing (everything possible) and additional blown-in borate cellulose in attic. Another blower door and duct blaster test.
Also a flex camera to inspect the 11 flex duct runouts as we think rotating brush duct cleaning had been done before we got here and there could be internal damage. I did spot one damaged flex about a foot down from the register with fiberglass showing. I taped it over. If camera shows damage, we would want new flex ducts installed and leave the main trunk as is (even if the camera shows bad stuff). No bids on this yet. I looked online for insulated 8 inch flex duct and took a rough guess of $1000, parts and labor for 150 feet of new flex duct. How does that sound ?
Finally, a new CleanEffects or AccuClean air cleaner.
Hope this is not too confusing but I am learning on the fly and probably know 25% of what I should know and should have done this years ago, but here we are........
Thanks in advance for any and all comments.
