We lost cooling in our upstairs system last week-end
(Goodman GSH140361 with AEPF303616 air handler). Called the company that installed it in July 2007 and a service tech came out late Monday and said that it had lost a little R-22 which he added. It was cool outside that night so unit did not run much or at all. Next day we were gone all day and came home to no cooling upstairs.
He returned today to inform me that the coil had been leaking (which he noted was obvious after coming out of the attic where the coil rsides- although no such notation was made when he was up there on Monday)
My questions as a person needing to not spend any more than is necessary:
1) Should a four year old coil be leaking?
2) IS it possible that the charge added on Monday adversely affected the coil (as in overcharge or similar)? Again, since no indication was given on Monday that the coil was leaking
3) I saw a service bulliten from Goodman (SR-034) indicating that the Heat pump and air handler used were not properly matched and were causing issues with High pressure switch tripping. Could this mis-match have shortened the life of the coil??
4) It appears the coil may be under warranty but I will likely have to pay labor and recharge. What should that be?
My question implying that overcharging may be at fault is not mean to insult the profession but as with any profession including my own, there are the good people and the not so good people. In these times of wondering if and when the next paycheck is coming, I like to be as sure as I can that I am on a path to smart use of the money I have.
thanks in advance
Grifftr3
thanks in advance
Grifftr3
