I'm new here and hoping to tap into some of the group wisdom. I've built a wedding venue in Alabama and need to install heat/AC and trying to figure out my best path forward. My intention is to self-install. To date, I've installed 2, 5-ton Goodman package units on my houses. I've also installed 1 mini-split. Here's my building
The main room is 90'X40' (3600 sq feet) which is 10' high at the sides, 16' high at the center. The roof is metal with thin bubble insulation underneath. The walls are wood outside and inside with R-19 insulation installed. The building is sealed up pretty well and temperature stays fairly consistent. I had my first wedding in February and was able to heat it easily with a couple of shop propane heaters.
I'm torn on how to design a system. Keep in mind, at this point I'm only concerned with AC for the main room. I'll put little mini-splits in the side rooms (bride/groom suites and bathrooms). Here is what I'm considering:
1) A single, 5-ton package system, run ducting in and up to the ceiling and tie off to the metal rafters around the 12ft mark. This would have a 90-foot run on the ducts.
2) 2, 3.5 ton units, coming from either end of the building. Could do package units or install splits with the air handler mounted up high. Each duct trunk would run 40 feet towards the center.
3) 5-zone mini-split system with cartridges installed about 15 feet apart.
On options #1 and #2, how big would you make the ductwork? 14"? I'm leaning away from option #3, as you'd have 5 remotes to deal with. I'd really prefer to have a single thermostat to adjust. Would appreciate any words of wisdom you'd care to share. Thanks in advance. Here's a pic of the inside:
