Hello Friends,
I hope this is the appropriate place for this question.
I am in the process of replacing the siding on my 100 year old garage. The old siding is wood with no sheathing behind it. I am adding sheathing and then will do some kind of vinyl siding.
I am preparing to add the sheathing, using zip 7/16 panels. This would ordinarily be fairly straight forward but I have a deck that is complicating things. The deck butts up against the garage wall and the old siding is above and below the deck. There is enough space to get the 7/16 panels in the gap and if I need more room I can trim the deck back.
I would really like to avoid having to remove and reinstall the deck boards as much as possible.
Questions:
1. Do I need to add siding underneath the deck or can I somehow make this work without needing to add siding underneath the deck?
2. How should I flash this at the bottom to ensure that the Zip panels don't just soak up water.
Pictures attached. I know they aren't the best. I plan to get some better pictures later today.
Questions:
