I'm looking at building a house in the country, a small place, nothing fancy. The first thing I need to consider is the septic, even though it will probably be the last thing to go in. I think the drain field will be located where trucks need to pass over, so I'll do the septic at the end. But I need to figure it out first.
The only septic system I ever dealt with was one that was divided into "brown water" and "gray water." The commode flushed into one tank, and the other water flowed to another tank and then on to the drain field.
The other day somebody told me not to bother with that, to just dump everything into one, but the other system made sense to me when I was helping to maintain it.
Any thoughts on this? I expect both brown and gray water would overflow into the same drain field, but should I split the outflow from the house like that? It's a from-scratch project, so I should be able to put anything in the ground that I need.
Thanks.
Thanks.
