1 - 8 of 8 Posts
If you maintain the filter the vent hose should only need to be cleaned a couple of times / year depending on use of course and the hose construction. With the length of ours and only 2 of us remaining in the house cleaning approx. every 3-4 years seems to be the schedule. Dryers aren't normally maintenance free.
· Usually Confused
How long is your vent and what is it made of? Also, does it run through an unheated space. With a properly functioning dryer filter there should only be a small amount of lint in the vent stream, but if it is overly long, not smooth or runs through a cold space what lint is present can fall out of the airstream and build up if not inspected.
Discussion Starter · #8 ·
we clean it out about 4-5 times a year
1 - 8 of 8 Posts
