I am new to this forum and would greatly appreciate some advice.
I recently painted the builder-grade oak cabinets in our guest bath. I lightly sanded, then applied zinsser cover stain primer.
Next I applied two coats of Valspar semi-gloss latex in a dark chocolate milk color. They came out beautifully.
Only problem is that although it's 5 days later and they are no longer tacky, the paint rubs off if barely bumped. I gently rubbed my thumb across it today and paint came with it.
It is not rubbing off down to the oak. Instead, the paint is coming off leaving the primer still intact. I know latex takes a while to cure (had I known that before the project, I would have considered an oil-based paint but what's done is done). My question is what do I do now?
It's not convenient to avoid using the bathroom for the next 6 weeks to see if the paint simply needs to cure. Do I apply a polyurethane? If so, would a spray poly work, or do I need to brush it on? And if this is a curing issue, would it be detrimental to apply a poly before the paint has fully cured? Thanks for the advice in advance!
