I removed an old ceiling fan from the dining room of a friends home recently.
Straightforward, or so I thought. I took down the old fan and light, installed the new light fixture, turned it on and bravo, it worked.
I actually only turned it on, never turned it off. Then my friend calls me later and tells me the light won't turn off. I go over today and did the following;
I replaced the switch, with a new one, thinking maybe that was the problem.
Nope, still stays on.
In the switch box the single pole switch has black and white wires going to it, so that makes me believe it is an end of loop?
The junction box has 4 black leads and 4 white leads, one which was terminated by someone else.
I simply connected black to black white to white. I tried each one of the black leads individually and only one worked, but the light still stayed on.
Obviously it is getting power somewhere, I think there may be a 3 way switch in there somewhere?
I'm baffled by what is going on here, anyone have a theory?
Thanks, Terry
Thanks, Terry
