Hello all,
Issue is I have started installing some HALO 3k disk LED lights for my house we are building and after getting about 10-15 installed some of them started to flicker. Went through and checked all connections and everything is hooked up correct and tight, and voltage is correct. If you turn some of the lights off the flickering stops (not all on the same circuits) Tried replacing some of the lights but no change. Running out of ideas besides replacing all the lights to a different brand. Wondering if anyone else has run into an issue like this.
Thanks.
Thanks.
