I assisted my friend install a 18000 BTU ductless Toshiba cool only system with indoor unit 208 VAC 3 wires connected to outdoor unit fuse box, vaccum the 2 copper pipe moisture and air then charge R410A to reach 120 PSI, insert fuse connector system run then use remote thermostat set to 17 degree C
, after couple hours indoor unit forzen with ice also to outside unit compressor, pull fuse connect then system shut down over night till all ice melt and reconnect power, outside unit fan run but compressor On and Off, on and OFF, CAN ANYONE HELP?
