First, is your tubing end cut straight? And, is it pushed all the way in?
You shouldn’t be able to pull out the tubing without having to depress the collet. But, your collet already looks depressed (too low) without you even holding it down. The collet should be a little higher.
If you pull up the collet, does it make the tubing impossible to pull out? If yes, then that collet being in a constantly depressed position would be the problem. You might be able to fix the problem with a collet clip. It goes between the collet and the rest of the fitting.
I’ve purchased John Guest quick connect fittings. Their collets stay up. Some generic fittings I’ve seen have collets that need a collet clip to stay up.
