Hi All
I need help wiring a second heating zone.
The system is a peerless gas boiler controlled by a Honeywell L8148E aquastat.
When the primary zone thermostat calls for heat it turns on the boiler and the circulator.
The second zone was wired through a relay which only turns on the circulator when its thermostat calls for heat.
This is a cold start boiler so it is possible for zone 2 to call for heat and wind up pumping cold water.
I know I need another relay so I can move zone 1 circulator control out of the aquastat, but I cant figure out how to connect both t-stats to the aquastat so the boiler will start when either t-stat asks for heat, but not back feed to the other relay and kick on the other circ.
Any help would be appreciated.
Thanks in advance
Ralph.
Thanks in advance
Ralph.
